  • 2 Replies
  • 4973 Views
PeterPi
I have an arlo which i will be installing at my pals place. Can I commission, register and check out the system at my place on my router, before re-connecting to his router. As far a I can see the only thing to change would be the ISP and IP address, so it looks good to go, but I'd like some confirmation before I proceed.
Pete
That will work fine as long as the final router doesn't have some sort of blocks set up.  If there's an issue, ensure ports 80 and 443 to netgear.com are open.  That's usually an issue only if someone has mucked about with security settings.
PeterPi
OK, thanks for that. If there is a problem at my pals house, at least I'll know the gear is working.
Cheers
Pete
