Temperature down to -30° C.
Hi,
I am living in Sweden there winters can have temperature down to -30° C.
How will that affect on the cameras?
I mean, its a lot of investement so I wanna know if the hardware will be damaged or not.
Arlo Security System with 3 HD Cameras (VMS3330)
Regards Alberto
Hi Alberto,
Arlo is not for you. Lithium batteries are not designed for operation in temperatures that low. You'll start to see a slight degradation below 10 degrees C. Below 0 degrees C the performance decays rapidly.
