  • 5 Replies
  • 3001 Views
rgrist
I just updated my app to the new version, and now all my temperature readings / recordings are in Fahrenheit instead of Celsius. With the previous app it was a simple switch to choose the units, but I can’t find it in the new version.
@rgrist wrote:
That’s how I could do it in the previous app version. I’ve just updated and the temperature settings doesn’t have this option. I can still turn on/off notifications and set the high low range. But no option for C or F choice in this spot.
I think @BrookeN gave you the wrong navigation instructions if you are using Feed.
On my iPhone, I need to
  1. press the Profile icon in the upper left
  2. press the Location (Home)
  3. Press Location Settings
Android should be the same.
5 REPLIES 5
BrookeN
To specify the temperature display units between Celsius and Fahrenheit:
  1. Launch the Arlo Secure App or log in to your Arlo account at my.arlo.com.
  2. Tap or click the circle with the silhouette or Settings on my.arlo.com (web).
  3. Tap or click App Settings.
  4. Select by tapping or clicking Celsius or Fahrenheit.
    Once selected, your temperature unit is saved.
rgrist
rgrist
Yes! That’s it! Thank you so much!
Yes, it is. Thanks.
