Since there is no easy way to contact Arlo, does anyone know how to submit a tax exempt form?
I can help you with that. Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
I also need the information, I will DM you.
I got your message, can you please respond to mine with a good callback number.
I received your message and have sent that information to support. They will be contacting you as soon as possible.
can you send me info on how to set up our account tax exempt. We are Exempt in NYS
Thank you for providing that information. I have reached out to support, they will be contacting you as soon as possible.
