Sync problems
Purchased a new Arlo camera system. Have been unable to sync 3rd camera after initial firmware update
Remove and replace the battery , try again.
Thanks. I have removed the batteries multiple times. I have even rebooted the main hub. I also removed all cameras and started from scratch.
I had a similar issue with one camera. i was finally able to sync while plugged in but that camera kept going off line.. It would wind up being a bad camera that seemed to be loosing contact between the battery and camera. Netgear did replace this camera 3 weeks ago and I have had no issues since the swap.
I had one camera that wouldn't sync even after multiple battery pull resets and even putting the camera on the shelf next to the base station. Eventually, I moved the base station a few feet further away from my wifi router and the camera sync'd right away. I suspect some sort of interference from the wifi router
