I recently purchased the Phillips Hue personal wireless lighting system. While this system connects to my home system, I cannot control my lights from afar without some pretty complex setup and requires that I leave a smart device home that I can connect into via the cloud. Kind of want my device with me 😞
I love the Arlo Pro, I can control the on off of my cameras from afar. It is easy to setup! It would be awesome if this same app supported the connection of other devices, like smart lights. I want to be able to turn on lights at will when I am away.
Possibly this function exists and I am just missing the how to do it.
kind regards
Pjkegler,
You might take a look at the Arlo IFTTT channel. There may be a recipe there that suits your needs.
