Stops recording or 1 camera sporadically goes offline
Has worked great for the first year, now it just stops recording or 1 camera sporadically goes offline. Live feed works but is choppy. I can turn off and on again but after an hr or so stops recording again. I’ve rebooted, removed unplugged but nothing seems to work. Was planning on adding 2 more cameras but now I’m worried this set up isn’t reliable? I love this system, hopefully it’s an easy fix. Please help
I would first try and reboot the base...then I would see if it can be move a bit farther away from you main router.
If the Live feed is choppy, it sounds like some form of interference ( unless your upload feed is slow )
