Stopped working...
  • 1 Reply
  • 3396 Views
JoelH
Got my Arlo yesterday. Worked fine. When I checked videos this morning it stopped recording anything last night. The schedule is set correctly to be on during the night. When I start it up the Getting Status shows a still from this morning.
Also, is the running man supposed to be in green or black. It's in black. Thanks.
If the 'running man' is black, motion detect is off and it will not record ( unless started manually )
I think maybe the schedule is wrong.
Easy to test; 1) TURN OFF THE SCHEDULE  2) TURN ON THE ALL MOTION ON mode ( one of your two defaults )
Let it run all night as you did with the schedule... if you get any recordings and/or your running man is green, then your schedule was incorrect.
Status when the cameras come up is static, it is the last view the cams took before they went to sleep and if it was run the day before that will be the cam view when started up.
