I am looking to setup an Arlo system at a location without any power and very limited mobile coverage.
Would you please recommend and advise if there is an Arlo solution that is able to be powered 100% using battery (no solar available due to indoor location) with motion based video recording to SD card?
Ideally battery life should be 1 month with relatively infrequent motion (i.e. 5 minutes recording per day).
Sorry, but all Arlo systems are cloud based and then mem card...and tho cams run on batteries the base units need power. ( except GO cameras, but you stated limited cell service )
You may have to look for a different system.
Then there is the power needed to run whatever router you use to host the Arlo hub.
Just another user
