An easy way to verify the MODES...
Turn on MOTION FOR ALL cameras... go to live camera view page, look at the top of the cameras and you should see a "green RUNNING MAN".
The running man in green means the motion is activated, if he's gray then the motion will not start a record.
Do this for the MODES you have to verify the cameras that should be active are.
If not then you have to EDIT the mode in question and turn the 'check mark' on ( green/ active ) or off (black ) as needed.
