  • 6 Replies
  • 5413 Views
Reidlos
So I read that this Arlo camera system tries to share the same channel as the netgear routers, well I have a neighbor (buissness below me) and I am apparently close enough to keep having thier channel change to mine no mater which i change mine too.  My default SSID was NETGEAR75 and this is called NETGEAR-arlo-XXXXX (XX= numbers)  i changed the SSID and channel but its copying my csame channel with a very simular BSSID.
Anything I can do?
6 REPLIES 6
Reidlos,
The Arlo base station is designed to follow the channel of the closest wireless router. You may be able to alleviate the issue by relocating your wireless router or requesting the owner of the Arlo base station locate his base closer to the router it is connected to.
For more on this topic take a look at this discussion: https://community.netgear.com/t5/Arlo-Wire-Free-camera/Is-it-possible-to-change-the-wifi-channel/m-p...
I hope this helps!
Gerry_D
Why?
OK, explain this to me... If I set my Asus RT-N16 (running Tomato) to a channel, the ARLO base station tracks and goes to the same channel.
Why?
Logically a signal on the same frequency will cause interference and degrade performance.
Is there a way to LOCK the ARLO to a specific channel?
Why not?
Gerry_D,
I hope this helps!
Gerry_D
Thanks James,
I saw that, but don't agree with it.
Crosstalk as mentioned is very high when they are on the same channel.
I URGE the so called engineers to take a look at these posts in other forums;
http://serverfault.com/questions/152920/what-happens-when-wifi-channels-overlap
and
http://superuser.com/questions/474280/considerations-about-using-multiple-wireless-access-points-wit...
In my humble opinion, (33 years of government electronics with automated test stations and tactical satellite ground stations), there is NO NEED for it to "follow" the strongest wifi signal. It has a wired connection and technically should AVOID a strong wifi signal to prevent interference.
I guess I will attempt to move the "base station" behind a brick wall so my wifi returns to a point as good as it once was.
Or switch to a wired system as this one seems to have been put into production before it was fully tested.
Gerry
Gerry_D
Well James,
I found an answer.
I set the Arlo base station around the corner in my basement, against a cinder block wall.
It had maintained itself on channel 6 while my router has channel 9 all to itself and speeds, according to a speed test app, have returned to pre Arlo status.
But here's one funny part for you.
I moved the base station, and waited until it found the cameras and the Internet. All was working just fine.
Then the next day I tried to access it from work and it would not connect .
For a few days it just was not working.
Late last night I remembered to trouble shoot the problem.
It took a few days to remember as I have a somewhat exhausting job.
Well I looked at the base station and the LEDs were out!
I looked where I had it plugged in and it was on a switched outlet that I use for my printer.
It was on the first night because I had used the printer and when I shut down my computer, as well as the printer, the power to the Arlo bast station was cut off!
Ya' gotta be careful where you plug it in!
DUH !!!
Gerry
good to hear it's fixed and you can laugh now.
think we've all been there at times
