Solved- Low battery even after batteries have been charged 100% - Sharing solution I found here.
  • 1 Reply
  • 7618 Views
  • 4 Likes
JoeSchmo
I've been having low battery indication on most of my cameras since I first bought them over a year ago. I have 5 cameras. All outside with silicone covers on all. Batteries fresh out of charger @ 100% but cameras show much, much lower. I read on here where someone took a pencil eraser and cleaned the contacts and it worked for them. I did the same on one camera and WHA-LAAA!!!! It worked! Then I went to another camera, did the same and no luck. I then took the eraser to all of the battery contacts as well and DA-DA-DAAAA!!!! Now shows 100% on that camera as well. I will be doing this to all of my cameras and batteries. Hope this helps others and THANK YOU to that person (Golear) who initially shared this info.
NightRanger
Thanks for sharing your solution, I'l keep that in mind.
NightRanger
