  • 4 Replies
  • 839 Views
Arlo-Amarillo
I am not finding support for any solar panel chargers. That product is not listed.  I have two for two cameras, one is working and the other quit.  I bought it in February at Best Buy.  Too late to return it there.  Trying to get some help to get it replaced.  None of the labels for this post match getting a replacement for a defective product.  Anyone have a link?
Use the app to go to Settings, Support to contact official support to request an RMA.
Alternatively, if you are in the US or Canada you can call 1-877-427-5680 between 6:00a.m. - 8:00p.m. PST
Arlo-Amarillo
No.  The person assisting me put me hold at every question.  Clearly wasn’t trained or had any idea of how things work.  Most frustrating experience of my life.  Still don’t have an RMA.  Probably will buy a different solar panel charger.  The support couldn’t be any worse if I need it.
BrookeN
Can you dm me a good callback number as well as a good time to call? You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
