  • 1 Reply
  • 2422 Views
Brucegt
The system records events to slow, if a car turns around in my drive by the time it leaves the drive the camera records nothing
steve_t
Master Master
The Arlo HD wirefree is relatively slow to record when motion enters the frame. To manage this, you need to ensure that the subject moves across the field of view, not towards or away from the camera. This is done by choosing a better position for the camera. The Arlo Pro cameras are significantly quicker to react and start recording. You can add an Arlo Pro camera to your existing system. Also make sure you've turned your motion sensitivity for that camera up to the maximum it can go without giving you loads of false alerts from trees swaying etc
