  • 2 Replies
  • 2109 Views
Goodmojo
My Verizon hotspot the ellipsis just has a port to plug in the charger it's the only means of internet that I have and I purchased this Arlo system thinking that that's all I need . obviously I'm very ignorant when it comes to the internet any help would be greatly appreciated
dcfox1
 You need an ethernet port to plug the base station into to connect to the internet. If not you can get a wifi extender with an ethernet port to plug the base in to. I never used a hot spot but i have seen posts were the wifi extender will work. If not someone correct me.
michaelkenward
Sensei Sensei
Sensei
As @dcfox1 says, you need an Ethernet port to plug the Arlo hub into. (Some newer Arlo cameras can connect to your wifi.)
One option is to get a wifi extender that can latch on to your hotspot's wifi. Then plug the Arlo hub into that.
This is a recognised way of adding another hub to an Arlo system for people who need to extent the reach of their  camera network.
Something like this:
WN3000RP | WiFi Range Extenders | Networking | Home | NETGEAR
Look for a device with a LAN port. No need for speed. The LAN ports on the hub are 100 Mbps.
Just another user
