  • 7 Replies
  • 9277 Views
  • 6 In Conversation
eawoodjr
How do I set up a second system with same email address for a home in PA when I have an operational system at a home in TX?
7 REPLIES 7
Buy a second system of cameras and base
Open up your account and ADD DEVICE ,  the base, then sync the cameras to that base...
There is NO limit on the number of bases on any account , service level ONLY controls the number of cameras you can use.
You can set up the second system at home ( I like this as it is easy to test/burn in a couple days ) unplug and move to new location and plug in...
OR set up completely at new location by using your same account
Greth
If adding a 2nd base and a 2nd location- are they able to arm/ disarm individually by location?
MarkN2016
I just added a 2nd system to a vacation home. After calling tech support, I had to register a 2nd act., using a 2nd email to get it going. Otherwise, the second system was going to be tied to the first with the same mode controlling everything the same way.
kkunzelmann
I just moved my system to a new home.  My home has a netgear box and I plugged the system into it.  Everything is green but I see nothing.  I tried forgetting the system by redoing my email for Arlo and resetting the netgear arlo box.  It has green lights for everything still and I dont see anything with the camera.  It was working fantastic before I moved 😞
ANy cameras attached to one base will only be configured with others on the same base - you can't span bases.  So, yes, they will be configured by location.
I think there was a misunderstanding somplace on either end.  ANy camera on a second base cannot act with cameras on the first - they're separate systems, even if using the same account.
Have you tried both the app and a browser?
