Setting up 2 homes
  • 1 Reply
  • 3283 Views
Davidbickerdyke
How can I use the arlo app to control 2 different homes?
You can run two accounts with diff passwords and emails or the easy way is to upgrade to a higher level of service that allows more the one base on the account.
The Elite level can run 3 bases and 15 cameras
Once you set up the second base at your primary location, take it to the second location with cams and plug in to an ethernet port there... easy
