  • 1 Reply
  • 3661 Views
jayco
can i set one camera to automatically to become active for certain hours and have the others off regards jayco
Yes. Use the Mode tab, click on your base and check out the modes, Armed in particular. Then create your own custom modes as you need. Once you create a mode with one camera​, reedit it and add more cameras as needed. Any camera without a rule will be disarmed. Use the schedule to automate it if needed.
