Setting Up A Second Base Station For Coverage Question
I am adding a second base to improve coverage. Do I need to pair the old cameras (closest to new base) with the new base?
You should sync the older cameras ( and newer ) to the base that gives the better signal...
That's the reason why multi bases is the only way to expand actual coverage.
