There were no operating instructions in the box...only the set up instructions.
How do I keep the camera's from sending messages to my cell phone everytime there is movement?
I want it to record whenever there is movement but not tell me about it.
I want to look it up later if there is an incident or something I "need" to look at.
How do I do that?
Lots of FAQs here. Read through them at your leisure.
Use the Mode tab, click on your base and check out the modes. Armed is selected by default. Edit it using the pencil or > icon on the right. All settings are in there. Now consider creating your own custom modes to have complete control.
As for reviewing videos, that's what's in the library. Click on things and check them out. Be sure to only click on save when you really mean it.
