  • 1 Antwort
  • 4015 Aufrufe
  • 2 in Unterhaltung
ah1gpilot
Hello;
Still learninng.
I ahve my schedule set up for one day (motions on) but want a different schedule for the next day.  When I change the schedule for one mode, it also changes the schedule for the second mode (Motions off).
Appreciate your help.  I need detail.
38
1 ANTWORT 1
DianaG
Hello @ah1gpilot
Thank you for the Post!
You reached the German Arlo Community - if you speak German, we will be happy to assist you in this language.
If not, here are some posts that might help you to configure the schedule as you want it:
Deleting and adding Modes to the Schedule
Managing Modes and adding them to the Schedule
I hope this helps.
Warm Regards
Diana
Arlo Support Team
