Schedule sometimes not arming cameras
duckson,
Consider a base station reboot (using the on-off button on the back of the base station)
After resetting the schedule and a base station reboot, are you still seeing this behavior?
Hi,
I had done system reboot the day before (relocated base station so both cams have 2 or 3 bars on iOS).
I think i have found the issue though....
I set the schedule on my iphone (6S plus, latest iOS version) originally, messed with it on my iPad Mini 2 (latet iOS version) and then the next day viewed it again on my iphone. The iphone was reporting it not being disarmed so i swiped off the app to shut it and reopened it and then it was reporting the cameras were armed and correct as i thought they should be as per the schedule.
For some reason between both the devices unless i manually shut one down to refresh it it seems to not be updating/refreshing properly.
duckson,
I have created and escalated a case regarding this issue. I will reach out to you in a private message with more details.
Thank you,
