Saving Live Feed in Library (4N71657X97BEA)
Just purchased my camera and Installed today, everything seems to be working fine on the motion activated footage. My question is on the Live Feed. When watching the live feed I can see what is taking place when there is activity, but when I go to the library that footage is not being saved. My concern is if I am watching the live feed and catch the perp in action, and I need to have the footage to play back it is not in the library. Is there something in the settings I need to change to have both the live feed activity and motion activated activity show up in the library, or should I just stay off the live feed and go in and check the footage from the motion activated shots??
Thanks,
Jarod
Live view disables recording. If you're using live view, you'll need to use the record button on the screen to manually record. That will show up in the library.
