  • 5 Replies
  • 22935 Views
  • 4 Likes
2ndrowe
I recently captured a video on my Arlo camera of a possible burglary suspect and it is saved to the cloud for 7 days & then records over again.
So I was wondering how to save or retain this video.
Any help would be appreciated.
brh
@2ndrowe
If you are using an iPhone you need to go to settings andscroll down to the Arlo App. Click on that and on the next page select Photos and select Read and Write.
Or go to your PC to download it and I don't think you need any access rights there.
Let me know what happens.
Brian
5 REPLIES 5
brh
@2ndrowe
Go to your Library in the app and play the video. At the bottom of the page you will see some options. Click on the icon that looks like a cloud with a down arro and says Download underneath it. This will save the video to your phone. I believe you can do this on your PC IDE and it will save the video to your Downloads folder.
Brian
2ndrowe
Thanks, already tried that but it then tells me “You need to allow access to Storage to download media”.
What do I have to do??
brh
@2ndrowe
Brian
brh
@2ndrowe
I don't know if they have change it recently, but the filename will be the time and date the video was taken, but it is in epoch time. To convert it to normal time use the epoch converter here:
https://www.epochconverter.com/
This might be important if you have to go to court.
Brian
2ndrowe
Thank you Brian, that did it.
