Rules and Recording Maximum?
  • 1 Reply
  • 3560 Views
SEAlb
Hi -
I have one base station and 5 cameras.  I'm setting up rules and a mode to run so that all 5 cameras will record if there's motion detected on ANY of the 5.  This is 25 rules.
No problem with that.
The problem I'm seeing is that I'm not getttng recording on all 5 cameras when motion triggers.  It's not always the same ones - but usually 2 or 3 only.
Can Arlo handle 25 rules?  Is there something else I should be doing?
Thanks -
s
It should... But things do happen.
Also be aware the max number of streaming cameras is 5 at same time. wonder the data thru put is a problem for you ?
What I would do it break it down to groups of cameras (based on needs) instead of all ...
My max is 3 cams linked together and they work
