Router r7000
6/23/16
Will the R700 work with both arlo and a usb drive connected. if yes, are there settings to be adjusted?
I've been using the R7k with a Seagate USB2.0 drive plugged into the fron USB3.0 port and have one camera attached with no issues. I've been using the beta firmware so don't know if earlier versions would work.
Edit: Didn't have to make any changes to any settings.
