Router Distance Question
This question is likely about future product plans. We own the Arlo security system and like the product. Our dilemma is we need to expand the security system, but the current range of a single router limits our ability to do so. Is there a workaround to this assumed restriction? Or, are their plans to provide a Mesh router solution that can extend coverage to a larger area?
Thank You.
`mark
You can expand right now with a second base. It just needs to connect to a mesh satellite, Wifi extender or powerline extender.
Thansk for that insight!
