It is pretty sad with arlo systems that have an issue with some of the hardware like Arlo hub if there is an issue with it you have to add the new hub delete all the cameras take them down from there locations reprogram them near the new hub and go re install the cameras
Can you explain more of what you are seeing? I would be more than happy to help.
