What batteries? This is the Q section - this camera doesn't use batteries. If you're referring to the wireless camera, it's always possible to have a bad batch but it would generally be unlikely. Do youhave another camera to swap batteries between?
did that with different batteries, still shows low
Deacon1949 wrote:did that with different batteries, still shows low
What type are you using ??
