I recently had a problem with one of the cams and Amazon (where I bout it from) is changing the full system including the basestation. What I cannot find is how to remove my existing basestation and cameras from my account (I am on a free account) and to replace it with the new ones. Any ideas? Thank you in advance for your help.
To remove ....
for base ;SETTINGS / BASE STATION SETTING / deactivate
for cams ; SETTINGS / SYSTEM SETTINGS - CAMERA ORDER / click green " X " in circle at camera line beginning
Haven't done this myself but you can go into settings, base station settings and deactivate the system. AFAIK, this should do the trick.
To remove ....
Many thanks It worked!
