Recording with no motion. VMB3010r2,, very. 3.3.0_15491
  • 6 Replies
  • 3922 Views
Bobcat12
I have two cameras that records when there is no motion. I've done the reboots and updates to no avail. Just to isolate all possibilities, I placed the camera in an empty bedroom, pointing into a corner, it still records sporadically. I need some advice. System about a year old. This started about six months ago and getting worst.
Bobcat12
Resetting from scratch appears to have remedied the problem. So far so good.
6 REPLIES 6
If still within a year and you have the receipt, open a case with support to possibly get the cameras replaced.
Bobcat12
14 months old and no.
Try starting fresh.  Remove all devices, including the base, from Settings, My Devices.  Open and close all battery doors. power cycle the base.  Add the base back in using Add Device on the Devices tab and sync the cameras.  Be sure to note any settings and modes/rules/schedule before resetting to help rebuild what you had.
If that doesn't help, it would seem that you have bad equipment that only replacement will fix.  Maybe someone's got hings on eBay or Craigslist.
Bobcat12
AZDesertGal
I have the same problem now for over a year.  The camera has been replaced twice but still having the same problems.  I just guess there is no fix for this problem as it is a piece of junk.
Batteries also very costly and last maybe 4 weeks.  Got one more set of batteries and when they go the camera also goes.  Need to get one that actually works and not by Netgear.
AZDesertGal,
You might try adjusting down the camera sensitivity for the problem camera. This should help reduce false triggers and preserve battery life. For more information on how this is done, take a look here: How do I change the motion sensitivity on my Arlo camera?
