Recording grey screen
  • 6 Replies
  • 6144 Views
Toddoo
Hi there, pretty annoyed at the moment.
Just bought a 3 camera system, 2 cameras bind fine and record well however I have 1 trouble camera that has trouble binding and when it does It can only show a picture of the camera view in settings it will not stream at all. I press live play and its just a grey screen. I record the grey screen and this shows upUntitled-2.jpg
I have reset the base and re binded the cameras, swapped batteries around however its still the same issue. I have the same issue on both the web app and android app. The trouble camera detects motion and it clicks to record howver I still get the same above video.
When live play is pressed on all three it appears like this
Please help its doing my head in.
Thanks,
Todd.
6 REPLIES 6
Swap cameras around temporarily to see if the problem stays with the camera or location. If its the camera, I think a trouble ticket is in order.
Toddoo
Hi there, Locations have been swapped as I thought there may have been interferance but that didnt fix it.
The issue stayed with the camera? Create a trouble ticket.
Toddoo
Yeah it did. Thanks I just did one. Will update when I have an outcome
judykathryn
I also have camera that will occasionally record images in gray but not always. I also reset the base and the camera but will do this about once  a day. Moved toanother location stillthe same. Options?
Have you tried the suggestions found in this thread?
