Recharging Batteries
I bought the recommended Tenergy fast charge station. I get all four green lights but when I put them in the camera says only 23%....I have tried both sets of batteries, the one with the unit and the one from Tenergy. Thoughts?
believe it or not, it could be the base and/or camera's firmware. that 23% is what the camera is claiming is remaining, tho. you still should have a full charge.
I use Nitecore and I use a low voltage to charge them back up. Takes a little longer but they last longer. I have 3 wireless cameras, one of them only shows 75%, the other show 100%. They all last just as long tho.
Thanks for the quick response....if that is the case, I will wait until I get the warning of low battery. Doesn't seem to make too much sense, though. Cheers
