Rechargeable charger and rechargeable batteries for arlo wireless cams in Australia
When will the Rechargeable charger and batteries for Arlo Wireless Cams be available in Australia? Amazon will not post these to Australia.
You won't be able to have the Tenergy ones sent from the US but you should be able to get some in Australia. I am using the Ultrafire brand along with a Nitecore charger and they're performing even better than my non-rechargeables were. You could try eBay but definitely watch out for fake batteries
Someone posted in another thread:
I have had success with purchasing Tenergy batteries and charger in Australia.
Go to a site called Ubuy.com. I have paid and had delivered the Tenergy charger and Batteries No Problems getting them here.
I have charged them and are now using them. They seem to work great, the battery's indicator shows full.
here is the linc. https://www.u-buy.com.au/
Cheers
Where do you buy yours from @steve_t? Do you have a link?
Sorry, I'm in New Zealand. I've just realised that the reason why mine seem better than the non-rechargeables where others have said they aren't is that my ones are 880mAh whereas the Tenergy are 650mAh. I guess I got lucky as all the ones claiming 2000mAh are likely to be fake
I got my Nitecore D4 charger from eBay
