I know this question has been asked lots of times and I have been away -- I scanned through for the answer and don't see one -- I brought the Edison Batteries SO DON'T WASTE YOUR TIME -- several of them had full life and was empty in 2 days - (: - can someone recommend the best rechargeable batteries for the cameras.
Vallorie
Thank you as I said there is so much info to have to read through everything just to get an answer. Also this site is sometimes not so user friendly. I did not want to comb through hundreds of messages to get the answer so thank you.
Vallorie
Vallorie
that is where I went to the last threads nothing about best ones to buy -- I just ordered Eagletac - thank you
Vallorie
No instant gratification , but knowledge is more important if you invest time before jumping.... you end up saving money in the long run.
Vallorie
What I meant is sometimes reading the threads is a good time spent learning before jumping... knowledge learned can save money
Did you get an answer as to the best rechargable to buy?
What brand of rechargeable batteries is ARLO recommending we use so it does not hurt the system?
On their accessories page, Netgear/Arlo recommends Tenergy
https://www.arlo.com/en-us/products/arlo/tenergy_rechargeable_battery_charger.aspx
Vallorie
