  • 3938 Views
  • 3 Likes
DFC
Hello. If you have used Night Core rechargeable RCR 123 batteries do they fit easily?. Have read that as these are protected batteries they may be slightly larger than CR123 disposables. Thank you. David.
Yes times change and so do procedures re the people that make decisions....
Just make sure you use good batteries... ones with over drain - over charge protection.
The nitecore batteries are longer than OEM, and yes a bit of tight squeeze but do work.
( li-ion 3.7 v - 650mahr )
DFC
Thanks TomMac. That's useful. Arlo support advise against using any rechargeables but I know many people do.
