Hi guys.
Having read some posts on here with regards to batteries it appears to be dominated by sites in US.
Can Anybody from England recommend some rechargeable with a charging station that isn’t going to burn a hole in my pocket?
Thanks !!!
Thanks !!!
if you can get them there, the Nitecore's work quite well
Would the following from Amazon do the job?
JINGBOSHI® Brand New 12 x 16340 Battery+Charger Dual Top Button New CR123A RCR123A 3.70V Li-ion Rechargeable for LED Flash Light Torch with UK-PLUG and EU-PLUG (note: Suit for Europe)
can't find the ones you're mentioning but its an unknown brand so should approach warily. The nitecore's, which I use in one of my cams, are offered though
