Hi, I purchased LiFePo4 rechargeable batteries for my cameras and I have installed 1 set of fully charged batteries, but my camera is still showing the batteries to be flat. Any suggestions?
I would like to thank you for your posts and contributions! I want to make sure you take a look at an article outlining best practices when it comes to batteries. For those involved in this discussion I encourage you to review Remember these golden rules for your Arlo camera batteries along with BATTERY WARNINGS AND SAFETY.
We strongly recommend using one of the following types of batteries:
- The non-rechargeable batteries supplied with your Arlo Wire-Free cameras
- Tenergy Li-Ion RCR123A 3.7V 650mAh rechargeable batteries specifically marked “Works with Arlo”
- Non-rechargeable batteries from other high quality, established, well-known manufacturers such as Panasonic®, Energizer®, or Duracell®
NEVER try to recharge the C123A batteries that came with your Arlo camera as they are non-rechargeable.
Thank you for sharing!
I am running 1.2.2545. Normal rechargeables work fine. Itts only a problem with lithion iron phosphate batteries.
Kithay wrote:Hi, I purchased LiFePo4 rechargeable batteries for my cameras and I have installed 1 set of fully charged batteries, but my camera is still showing the batteries to be flat. Any suggestions?
Old thread;
2015-05-15 01:58 AM - edited 2015-05-15 02:11 AM
Bought and set my Arlo 4 camera system 5/4/15 around 3-4pm. As soon as the provided Energizer batteries dropped 1 bar on the battery indicator, I ordered rechargeable batteries and chargers.
- (8) Tenergy Li-Ion 3V 900mah (blue/silver) with 4 dock charger, X 2
- (10) Tenergy LiFePO4 750mah (green/silver), X2
As soon as they arrived some of the blue 900mah needed a 3 hr charge.
The green 750mah were charged on arrival.
5/14/15 I got a 1 red bar battery indicator / 10% email at 8:30pm.
I changed out the old Energizer one-use batteries with the blue 900mah Tenergy, reset the camera in position, THEN noticed the battery indicator wasn't corrected to a full 3 green bars via iOS app but still 1 red bar (should've checked before mounting). I checked to see if the camera would work, it did but had a longer than usual delay with live streaming.
I tried the green 750mah Tenergy, in the other camera I wanted to change to rechargeable batteries even tho it had 2 green bars (both high traffic, best quality), and the battery indicator dropped to 1 red bar. I then tried the blue Tenergy in this same camera and got the same results.
I ended up putting the old Energizer batteries back into the cameras and now have both cameras at 1 red bar via iOS and website through computer.
Support said that the Engineers tested these batteries and found that they WILL NOT WORK. They said that I need to buy 3.6V-3.7V Li-Ion Rechargeable batteries and added that I should NOT use the green 750mah LiFePO4 Tenergy. They said that 3V is not enough to operate the camera. I expressed my confusion since the provided Energizer batteries are 3V as well. So that doesn't make sense... rechargeable or one-use shouldn't make a difference, 3V is 3V. They said thay there is a specific discussion referring to ONLY USE 3.6V or 3.7V Li-ION RECHARGEABLE batteries on here but I can't find where a Netgear/Arlo rep says this, just customer discussions about trial/error. Also, this is NOT indicated on the box, app, etc. as operating requirements. Now I'm stuck with a bunch of batteries I can't use? I asked about a possible software problem and they said it was not a software problem.
Well thats nice to know considering I spent $100Au on those batteries. Arlo will be hearing from me about this one.
