Recharable Batteries
  • 4535 Views
allangoveas
Hi,
I wan to buy these rechargebale batteries from Amazon as suggested by Arlo
https://www.arlo.com/en-us/products/arlo/tenergy_rechargeable_battery_charger.aspx#Tenergy Battery Charger Combo
But unfortunately they do not ship to New Zealand
Any idea how cna I purchase these as my batteries are ruuning out of power
manfredz
Hero
Hero
a bit back someone in australia posted this.  may help:
I have had success with purchasing Tenergy batteries and charger in Australia.
Go to a site called Ubuy.com. I have paid and had delivered the Tenergy charger and Batteries No Problems getting them here.
I have charged them and are now using  them. They seem to work great, the battery's indicator shows full.
Cheers
allangoveas
Thanks Manfredz Prodigy
Unfortunately the tenergy charger available on ubuy.co.nz needs a power converter as well as it is desgined for US power sockets.
So not too sure whether they will work efficiently.
Any other options - is this option viable for arlo cameras? Are they safe to use?
https://www.pbtech.co.nz/product/TOLNIT0085/Nitecore-Battery-NL166-RCR123-Li-ion-Rechargeable
manfredz
Hero
Hero
a power converter should have no effect on the charging process.
In one cam I use these Nitecore batteries, they work just fine.  But you'll still need a charger. The Nitecore i4 is 100-250V 50/60 Hz so you'd just need appropriate power plug, But the Tenergy with power converter would also work with Nitecore batteries
