Recently my Arlo wireless camera has started recording " ghosts" from time to time day and night..
  • 1 Reply
  • 2748 Views
lisawilliams
I've had my Arlo wireless video cameras for 7 months. About a month ago, the outside camera began recording a white misty vision.  Sometimes at night, sometimes in the morning, once in the  light of day. It doesn't happen every day. Is there something wrong with my camera?
Could be condensation... Pull camera and clean off the outside ( can help stop outside condensation ), check inside for moisture.
If you do find moisture inside, there are the old electronic fix tricks for like cell phones...remove batteries
1) put it into an amount of uncooked rice to cover for a few days ( opened battery door )
2) put into a SLIGHTLY warm oven ( less than 130f ) for an hour or so ( on a potholder with battery door open ) to dry out
Check o-ring fro a good seal
