Re: Average battery life?
I bought re-chargeables but the kind I purchased won't show ANY bars on the battery meter. It just shows a blank red box....wondering if I should buy the ones you have???
demilleh wrote:I bought re-chargeables but the kind I purchased won't show ANY bars on the battery meter. It just shows a blank red box....wondering if I should buy the ones you have???
What did you buy? voltage?, ratings?
