Range
  • 7 Replies
  • 4740 Views
Twosmiles
does anyone else only get a range of about 15 ft. Even with a fairly new battery?
7 REPLIES 7
It can be all about location and position.  A downward tilt with motion across the FOV works best with the edges seeming to have the best detection.  It's trial and error.
Twosmiles
I am not talking about detection but live view....
Twosmiles
Guess I don't understand then.  Live view doesn't have a "range".  Detection does.
Twosmiles
Live range is the distance between the camera and base that you can see the camera output.
detection is a subset, I.e. No camera then no detect...
Ok, now that we have the terminology set, the answer is "simple". (HA!)
The specs say up to 300 feet but that depends on a ton of things - 2.4GHz. interference from other devices, walls, ceilings, wiring, ductwork, the phase of the moon.  Straight line with no other obstacles could get you there but in a realistic scenario it's far more complicated.  You can only rely on testing and, to a degree, the WiFi signal strength shown in the app/web page.  It could be horrible (10 feet) or not bad at all (50-100 feet).
"It depends." (TM)
As mentioned spec max is 300 ft just like any other wifi and works at a frequency of 2.4ghz
As you may/may not know, 2.4ghz is line-of -sight radio waves... they can be reflected and/ or blocked. There is also a large amount of interference out there in the same frequencies , like microwave ovens, other wifi systems.
I have use the cameras to max about 150 ft... but will say it's been under good conditions of high elevation, no real blockages, line of sight contact.
The only  way to know what  works/how far in your environment is to test it.
