RI
3 cameras on my home google wifi. One camera on Arlo hub.
Should the one on the hub be switched to Google wifi?
How do you do that?
How do you do that?
What model camera? Some don't support direct connections to WiFi. If the camera opens, you can open the housing and remove the battery. There's a label inside. You can also go into the support center in the app, and select the camera. Scroll down to the product ID field. (If you just see Hxx, then you are looking in the wrong place).
Also what model hub (there is a VMBxxxx label on it).
