RECORDING 10 SECONDS AND STOPS.
WHAT DID I DO WRONG AT INSTALLATION? IT ONLY RECORDS 10 SECONDS AND STOPS.
CAN I GET ADDITIONAL ACCESORIES FOR THIS CAMERTA SUCH AS WIRELESS CONNECTOR FOR MY NON SMART TV?
sudamerica1 wrote:WHAT DID I DO WRONG AT INSTALLATION? IT ONLY RECORDS 10 SECONDS AND STOPS.
Are you using the default mode Armed? If so, you should edit the recording length. You must edit the mode, then edit the rules of the cameras you want to increase recording time for.
If your TV has Android and is able to connect to the Google Play Store, you can download the Arlo app.
