R7000 instead of base station
When i purchased my first cam, I was using the Arlo base station, hardwired to my R7000 router. The latest firware upgrade on the router enabled me to bypass the base station. My problem is - when i try to set the mode, the router is the only equipment that is showing up. This will not allow me to have one cam armed and another one unarmed. How can I correct this situation?
Did you remove the cameras and base from your Arlo account? You'll need to do that first (leave the base and any cameras you may want to use in that configuration, if appropriate). You've already added the router but you'll then need to sync the cameras and create modes and rules.
Thanks - figured it out. The instructions I got with the base station were not at all applicable to the router setup. Icreated new modes that work the way I want it.
