Push Notification - Not Stopped
I turned off the push notifications, email and notifications, but the phone notifications continue. I checked the based station via the PC and I checked my phone (Android), the notficitions continue even though the options are not checked. Please advise.
after you made the change did you remember to save the change (after you go back , you find the save button below bottom of screen so you have to scroll to it
Yes, I saved the updates. I even went out of, and back into, the application to confirm the options were not checked.
Power button recyle/reboot your phone
If that doesn't work you can go to app settings and clear the cache and force a stop OR just uninstall and reinstall the app
both take mins to do
