  • 2799 Views
SolutionSeeker
Hello
Push Notificati​ons stopped working on my Samsung S5 (Android 5.0).
I tried very posibility posted on the community. Nothing works.
Is there a solution out there ??, Mr. Arlo Netgear perhaps ??Smiley Indifferent
Paul
The usual suspects are reinstalling the app and checking the app Settings to verify that notifications are enabled (try disabling, save and reenable and save).
SolutionSeeker
I tried everything. Nothings works..... to solve the problem.
Phone is updated, re-installed, put notifications ON, re-tried: nothing. Did an un-install, re-install, checked and...nothing.
But we do not give-up hope..
To be clear, turning notification off and back on, I mean in the phone's app settings. Go into the phone settings (gear icon), find Applications and then Application Manager.  Scroll down to Arlo and uncheck the Notification box, answer the prompt and exit.  Go back in and enable.  Maybe that will help.  The notifications in the Arlo login only works for email.
