Problem with batteries
  • 3757 Views
Dottvima
Hi, I use Arlo wireless, I have 5 cameras
but I have problems with 2 of these,
one consume the batteries very quickly
and the other although I put new batteries,
the yellow battery light is flashing low.
Even on the PC.
the icon of battery state tells me that the battery is low. How to remedy it? thank you
steve_t
Master Master
Chances are your new batteries are low. Have you got a multimeter to check their output voltage? Are the batteries all in with the correct polarity and with good contacts?
Dottvima
I have checked with multimeter : the charge is hight.
The contact is right because the light yellow blink!
I don't know wat to do!
manfredz
Hero
Hero
maybe a dirty contact.
Put the low batteries in one of the good cams.  What does that tell you about the batteries then?
