Power Supply Adapter Suddenly Stopped Working
Today when I opened the Arlo app on my phone I got a message that says that the base station is not connected to the Internet and to power it on. I went to check and found that the base station is not working at all. I tried the power button on the back and I tried changing the location of the adapter. Still dead. I figured that it has to do with the power adapter so I used my router's power adapter and as I expected, the base station started working. I purchased the Arlo security camera (3 Camera Kit) only two months ago. I don't have an extra power adapter to use with it and I'm worried that if I use anything other than the Netgear adapter that came with the product it could harm the base station. What do I do now?
That was risky using the router's power supply - hope you didn't damage anything. If the voltages are the same, no issue but many devices use different voltages, not to mention swapping between + and - for the connector. Don't do that again without checking voltage and polarity.
As for the initial issue, it's trouble ticket time for a replacement. If you or someone else knows the specs and issues, you could possibly use a universal power supply with the proper connector and polarity to get by in the meantime. You could also contact the store where you initially bought the system to see if they'd swap one out for you.
Here's the specs if needed... coaxial plug appears to be 5 or 5.5 mm center positive
The above picture tells you all you need as does TomMac's words. 12VDC, 1.5 amp, center conductor is the positive one.
Amazon offered to replace the whole thing but they said I would need to return the product. I don't want to go through all this. I just want a new power adapter. They said if I need the adapter I'm going to need to return the product. They couldn't send me a power adapter so they issued a partial refund of $65. I'm going to have to buy from a third party seller.
Will this do? Will it fit in the base station?
http://www.amazon.com/AC-12VDC-1-5-Amp-Power-Supply/dp/B000BYNYJE
The first one looks doable if the plug fits and has the right polarity. The second is for the EU - are you living or visiting there? As with any of these, the onus is on your anus to verify that everything is right before plugging it in. You pays your money and you takes your chance...
And I don't live in the US. The second one is the type we use here in my country.
Sorry, trying to inject a little "humor"...
In any event, any non-standard power adapter carries risk. Whether it's real or just perceived is up to you to determine. Will any other adapter work? Likely but if you blow something up it's all on you. To keep the risk out, you should use the dedicated supply. It's up to you to decide.
Also, it wasn't obvious where you live. Since you've made that clear, the first adapter wouldn't be appropriate since it's for NA power connections. Of course, you could use another adapter so it plugs in properly but that just adds complexity. Either way, you still need to verify that the plug for the base station is of the proper size and polarity.
How do I contact customer support?? I entered the serial number and date of purchase and got "Thank you for providing us with the necessary information". I want to talk to a customer support rep. Is there any way to do that?
Still want to talk? Just tell us where you’re calling from:
0844 875 4000
Or look here and pick country; near bottom of page
http://www.arlo.com/en-us/support/contact.aspx
What is wrong with Netgear's customer service? I'm still waiting for my replacement adapter. Unbelievable. They haven't even sent me an update. I live chatted with a customer service rep and explained the issue. He said we'll send you a replacement and asked where I want it delivered. He said I would need to send an invoice, proof of purchase to the email he gave, and I did right away. This was on September 26. On September 28, I got a reply from Support saying "The files have now been attached to your case. Here is your case number for your reference...." I replied back inquiring when I can expect the replacement and got no answer. It's November 20 today. What kind of customer service is this??
R_S9,
I will reach out to you in a private message to help resolve this issue.
I replied to your message the same day. Did you receive it?
