Poor function on motion sensor / slow recording start when triggered.
I have problems with the motion sensors. I have one cam mounted on my driveway up to my house and one mounted in same direction on my entrance.
When a car come driving up my driveway, the motion sensor reacts but it is too slow/ or the camera startup is too slow so the car can pass without being filmed.
I have solved it so the 1:st camera on the driveway trigger a recording on the entrance camera and in this way i can see what happens.
I dont see why i have to make this workaround, is Arlo sensors this poor or is it the startup from standby that is the problem. If yes, why dont you make a firmware where you can choose between current state of standby and a more "active" standby where the cam starts more quick and the cam consumes more battery ( that would be ok for me, i use rechargeble batteries anyway).
I have motion detaction set to 100% sensitivity
Please see drawing attached. The white arrows point at the cam locations.
Arlo cameras do have and have had a slower start up time... but also the sensor really is only effective to 20ft ( on original, 25ft on pro/pro2 )
But what your doing is a solution for a long driveway
Your end around is the same as mine, I use the 1st camera to set off recording on the second camera.
You cannot rely on these cameras alone to detect a threat or notify you of the presence of anyone or anything.
I've asked repeatedly for a fix , a motion sensor you can pair with each camera , instead , they now call these "legacy" cameras , and their R&D seem to have moved on from them.
I love their picture quality during the day , but they dont detect motion when needed. A branch in the corner of the field of view , yes.
A person walking past at 2 am , scaling my fence , no.
Just an empty video of where he was.
@TomMac wrote:
But what you're doing is a solution for a long driveway
I agree.
FWIW, the cameras also are designed to be most sensitive for side-to-side motion. But your cameras are already set up to take advantage of that.
If you had a pro-2 or ultra, then powering the camera with AC would help. But not with the older cameras (and getting power to yours doesn't look very practical).
It would be good if they had a stand-alone motion detector, as that would be less expensive than deploying a second camera.
